Computers & Internet Logo
LJ Bailey Posted on Jan 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What processor and where can I get one?
Compaq presario v6500 GT406EA (V6642EM)
etrc_new
Level 3:
Master:
  • Compaq Master 752 Answers
  • Posted on Jan 18, 2016
etrc_new
Compaq Master
Level 3:
Master:
Answers
752
Questions
Helped
283042
Points
3763
This 'notebook' was shipped with an AMD Turion 64 X2 Mobile Technology TL-58 CPU, See http://www.cpu-world.com/cgi-bin/IdentifyPart.pl There are three variants. This CPU is "probably upgradeable" according to the FAQ in the pages linked to from my ref.
The HP webpage for this model is Compaq Presario V6642EM Notebook PC Product Information and the specifications (linked to from that page) are here Compaq Presario V6642EM Media Center Notebook PC Product Specifications
The maintenance & service Guide might tell you which, if any, other CPUs can be fitted.
HP say follow the following steps to determine which CPUs are available for your PC HP and Compaq Desktop PCs Upgrading or Replacing the Processor but I don't hold out much hope as to determining the m/b type.
Incidendentally this model can accept up yo 2 x 1GB RAM
18.January.2016
Presario v6500 manual
http://h10032.www1.hp.com/ctg/Manual/c01295079.pdf
Generally upgrading the motherboard is easy, as long as it fits in the case. However it's what goes on the motherboard that will cause you problems. For example if you are fitting the old memory cards and the processor any other cards that fit into the slots, they might not work with the new board, so you could finish up replacing them too!
When esc key pressed only starting my presario v6500
disconnect the keyboard from motherboard.then checkif problem not occured it means problem from keyboard, then replace your keyboard.
1helpful
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3369429&
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,
http://www.sparepartswarehouse.com/Compaq,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Regards,
joecoolvette
HI I have a hp/compaq presario 6500 v6500 product no: GT406EA Serial no: CNF7372MTN Turn on, power to the pc. battery light ok, can here fan starting, but no post double beep & absolutely...
2 beeps usually means a memory error, however, you should get an error message. Try removing and re-inserting the ram modules one at a time
I assume you have tried to see if the ac adaptor is putting out the correct voltage?
Compaq Presario V6500 has on board graphics card a separate card be installed, are there any options.
You can install a better graphics card in the AGP slot. You most likely need to disable the on board graphics card from the BIOS.
2helpful
Give me sound driver of compaq presario v6500 with xp
Follow this link and select your exact model number and OS..
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3369426&taskId=135
1helpful
Video and lan driver for compaq v6500
i need all drivers of compaq presario v6500.. pls... help me!!!!! thanx
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
