When it stops at the end of the spin it makes this loud screeching noise and stops really fast. The clothes are still wet, I really need help. I cant afford to have a tech look at it.Please help
SOURCE: End of spin cycle on washer
I just made this repair and was able to clean lining and drum and coat with silicone spray, did not have tool for brake spring. the spring and gravity took care of removal (BE CAREFUL), and for re-installation I used longer screws of same thread size and pitch(10-24x1-1/2",I believe) and was able to pull brake drum back into place. suggest pulling from 3 screws evenly spaced around drum,a little at a time(2-3 turns each). on my machine,the extra length of screw was on no concern, but check yours. after tightening, you can re-install origional screws one at a time, they may be better suited for it(locking head). If you have the machine leaning on it's side as I did, it will help to remove front panel and support the wash tub on the side to keep it from sliding off center, I used a wad of rags. It works fine, if it will last(silicone). If parts and money are not an issue, I would probably use new stuff.GOOD LUCK
SOURCE: Washer screeches when the spin cycle stops and now makes a loud noise at all times.
is the bottom foam shipping base still on the washer
SOURCE: loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
SOURCE: loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
SOURCE: loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
