Dryers Logo
Barbara Easter Posted on Jan 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replcd old switch. moved wires one at a time blk=L gray=1 brwn=2 pur=3. light won't work
It worked before i replaced switch. don't know model or mfr. i live in apt, fan was already here
Kirk Augustin
Level 3:
  • Master 2,019 Answers
  • Posted on Jan 15, 2016
Kirk Augustin
Master
Level 3:
Answers
2019
Questions
0
Helped
825749
Points
5971
Did you remember that the wall switch has to be on first before the pull chain will do anything? I am assuming ceiling fan. What kind of fan are we talking about?
Color wiring diagram
with the 5.4 engine
violet/white--- tps reference
gray/white ------ tps 1 signal
orange/lt. blue -- tps signal return
gray/red ----- signal return
red/white ---- reference voltage
with a 6.0 diesel
tan--------ref. volts
yel/white- apps 1 signal
blk/org---- signal ret.
white/red- apps 3 signal
gray/blk--- apps 2 return
white------- apps 2 signal
blk/white-- aps2
hope this helps
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
2answers
Can you supply me with the colour code for the wiring on the alarm/central locking unit under the dash on a 2002 vw golf ? i am fitting a remote start alarm and when i remotely lock the doors i need the vw...
This is what I have for the Golf 2001:
' ITEM ' WIRE COLOR 'POL' WIRE LOCATION '
' 12V 'red '+ 'ignition harness '
' STARTER 'red/gray '+ 'ignition harness '
' IGNITION 'black '+ 'ignition harness '
' ACCESSORY 'black/red '+ 'ignition harness '
' POWER LOCK 'yellow/blue '- 'drivers door module *1 '
' POWER UNLOCK 'green/red *2 '- 'drivers door module *1 '
' LOCK MOTOR 'purple/yellow ' 'drivers door module *1 '
' UNLOCK MOTOR 'blue/yellow ' 'drivers door module *1 '
' DISARM DEFEAT 'pur/yel or blu/yel ' 'passengers door module *3 '
' PARKING LIGHTS + 'gry/red & gry/blk ' 'drivers kick panel '
' HEADLIGHTS 'yellow/red '+ 'headlight switch '
' DOOR TRIGGER 'blue/gray *4 '- 'comfort module *5 '
' DOME SUPERVISION 'blue/gray '- 'comfort module *5 '
' TRUNK/HATCH PIN 'brn/blk or brn/blu '- 'hatch light '
' HOOD PIN 'brown/red '- 'comfort module *5 '
'TRNK/HTCH RELEASE 'brown/black '- 'comfort module *5 '
' FCTRY ALARM ARM 'arms w/ lock ' ' '
' FCTRY ALRM DISARM 'disarms w/ unlock ' ' '
' TACHOMETER 'green/stripe ' 'ignition coil '
' SPEED SENSE ' ' ' '
' BRAKE WIRE 'red/black '+ 'drivers kick panel '
' HORN TRIGGER 'black/yellow '+ 'comfort module *5 '
' WIPERS 'grn/yel and green '+ 'wiper motor
*1 The drivers door module is located in the drivers door.
*2 A double pulse will unlock all doors and disarm the factory alarm.
*3 The passengers door module is located in the passengers door.
*4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are brown/white and are all located in their own door at their own door module.
*5 The comfort module is the main control module located under the drivers side of the dash.
Use this diagram for the door trigger isolation: motorsport.com/images/install_notes/149.jpg
Use DIAGRAM A.
Hope this helps.
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
1helpful
What is the grill cap on the PUR filter? I don't seem to have it.
HI, Is the filter down near the floor in the kick plate?
If I had a model # I caould look this up for you.
Thanks
VIc
Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Top Dryers Experts
john h
