<p>A very common and increasing popular
source of <b>supplemental heat</b> in the last few years has been the
<b>oil filled electric radiator. </b>
<br />
<p>These <b>radiator
heaters</b> are filled with an oil that circulates through the fins
of the heater and is heated by <b>electric heating elements</b>. The
result is a steady even type of heat that has a lower surface
temperature then many <b>space heaters</b>, making them a great way
to get <b>supplement heating</b> into a room when you have pets,
small children or combustibles near by.<br />
<p><br />
<br />
<p>One of the big
questions that comes up with these <b>oil filled heaters</b> is what
to do if they start to leak. The answer is that if the<b> oil heater</b>
starts to leak then it is no good anymore and needs to be disposed
of. These<b> heaters are filled with oil</b> at the factory and then
are sealed tightly. Because of this there is no need to ever <b>refill
the heater with oil</b> again. The heaters are sealed with the proper
oil inside for the <b>best heating efficiency. </b>
<br />
<p><br />
<br />
<p>So what this means
is that if you have one of these <b>oil filled radiator heaters, </b>you
will never have any <b>maintenance</b> or worries about <b>adding oil
to the heater</b>. But if there ever is a leak then the heater is
also no good and will need to be throw out and replaced. Very few of
these <b>oil filled heat units</b> ever leak, but as is always the
case there are always some that do.<br />
<p><br />
<br />
<p>A word of caution
about heating efficiency. Always remember that when <b>heating with
electricity</b>, the <b>laws of physics</b> always apply. <b>For
every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br />
<p>There is no way to
get any more or any less than that, so if anyone tries to tell you
that their electric heater is more efficient then the next one they
are not telling the truth.<br />
<p><br />
<br />
<p><br />
<br />
<br />
<p><br />
<br />
<p>One of the big
<br />
<p><br />
<br />
<p><br />
<br />
<p><br />
<br />
<p><br />
<br />
No you do not have to fill this. The problem is either the heating element or the Tstat. my suggestion is to replace the unit. This are disposable units meaning they are cheaper to replace than repair.
Turn it off and if it is not under warranty dispose of properly. These are sealed units and there is no way to refill it. They should never leak, and when they do that is because of a bad weld or rusted metal condition. Sorry this is probably not the solution you want, if it is under warranty return it to where ever you purchased it. It leaks when it is warm because the oil gets hot and thins down to about the viscosity of water.
These are sealed oil heaters and do not require refilling, if yours is leaking then it is bad and should be disposed of. They should not use oil or leak oil ever.
take a hole punch and knock a hole in each end, one on the top, one on the bottom and drain the oil into a 2 litre plastic bottle. Now you can recycle both!
