Were is fuse located for check engine light,not in owners manual.
Most all engine control modules I have seen , turn on ck engine light when you first turn ign switch to "On" this is a test for the light bulb then they go out a second later , other than that have someone use a scan tool to ck 4 codes and see if there correct , Not all fault codes will trip a ck engine light as some are considered a minor fault (1 example: low washer fluid)
a little known fact is that most national chain auto parts stores will ck your codes for free !! ask them!! they just might like to have the chance to sell you the parts to fix it
