SOURCE: 1999 Silverado drivers side power window will not go down.
the power window motor is bad if you let it sit for a few minuites after it stops you can push the switch and it will start moving again
SOURCE: power window goes down, does not go up all the way.
You might have a circuit breaker getting weak in that circuit, as some manufacturers incorporate that, and it resets itself when key turned off. That might explain why inches after key turned off & on. Does your manual, or fuse panel have anything labeled as circuit breaker? Have a listen under dash on both sides of vehicle, and down near kick panels by feet area while someone tries window for you, and see if you can by chance hear circuit breaker trip (click) . Actually, get them to jog it down & it may be easier to hear & locate.
SOURCE: wiper fluid motor?
washer pump located in washer jar. Either washer pump is inop, or possibly a clogged water line or nozzles.
SOURCE: 2003 Ford Escape leaking red fluid
Sounds like you need a new power steering hose. To verify this, I would dry up any wet areas on the hose and pump with a towel, get a flashlight and start the vehicle and try to determine the exact site of the leak which is usually at the ends of the hoses. Good luck!
