·Plug in the microwave and connect to a power source.
·Locate the "Clock" or "Time" button on control panel.
·Press the Clock/Time button to access clock-setting mode.
·Enter current time using the number pad on the control panel.
·Confirm time by pressing the "Start" or "Clock" buttons.
Source: How to Set Clock on Hamilton beach microwave
PDF]set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../set-up_guide_en_o...
PanasonicPress "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
[PDF]MICROWAVE OVEN - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesIf materials inside the oven ignite, keep oven door closed, turn .... This is a standard 12-hour clock (12:00-11:59). To Set: The microwave oven must be off. 1.
[PDF]BUILT-IN MICROWAVE OVEN - KitchenAid
www.kitchenaid.com/digitalassets/.../Use%20and%20Care_E...
KitchenAidSee "Clock" section. The microwave oven will also turn off when the door is opened.... Use the dial to select options, set the clock, set cook time and cook power ...
[PDF]
