LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
