Question about Xact Communication XG2200 Cordless Phone
I have a BT Studio 1100 twin phone system. Base 2
I have a BT Studio 1100 twin phone system. Base 2 will not get dialing tone or receive calls although the icons on the display all appear to be correct. It will not de-register from the base either...At the setup menu the message unavailable appears on the screen.
SOURCE:
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Posted on Nov 19, 2007
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Posted on Feb 29, 2008
SOURCE: GE 900mhz model 26936GE2-C
My problem is still the same.I didn´t droop it, anda a have already changed the battery, but the fone doesn´t accept the base.
Posted on Mar 02, 2008
SOURCE: BT Studio 1000 4 handsets
hi problem with bt studio 1000 phone changed battery and phone still not working just a hi pitch sound when you press it .
please can you help me.
Posted on Oct 27, 2008
SOURCE: How can i delete messages on my BT Studio 1500?
go into menu, go to "play message", scroll down to "all messages" press the tick button, when the messages play press X (secrecy) button.
you have to delete them one by one
hope this helps
Posted on Apr 05, 2009
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
How do you register a second phone to the bt studio 1000 phone
1. Check the manual of your new handset on how to set it to registration mode.
Then on your BT Studio Base
2. Press and hold the base (page) button for at least 10 seconds until you hear the validation tone. then release. That's it.
for this model, you can only use up to 2 handsets.
hope it helps.
May 05, 2011 | Cell Phones
My BT studio telephones are not working. No dialing tone on receiver. Dialing in goes straight to answer phone. Incoming line has been checked by my service provider and confirmed as OK. I have tried my N0...
The main socket has an external socket and an internal socket. When I plugged the phone into the internal/ primary connection the service was resumed. There must be a fault between the 2 points . I will have to get a Telecoms engineer in to fix it
Dec 15, 2009 | Lands Phones
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Bt quratet 1100 no dial tone
Sounds like the phones have not been registered to the base unit. Look in the manual for directions on how to get the phones and the base unit to talk to each other. Sorry, I don't have any details on theis model to look up the instructions.
Jul 23, 2007 | GE 25831GE3 Cordless Phone
Xact Communication XG2200 Cordless Phone Logo
445 people viewed this question
Top Xact Communication Lands Phones Experts
Marvin
Marvin
k24674
Are you a Xact Communication Lands Phone Expert? Answer questions, earn points and help others
