Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
F2 This error code indicates that drain times are longer than expected. If the washer won't drain there might be a clogged pump or hose. It's
common for small socks or other small clothing items to get into the
water drain system and clog the hose leading to the pump or the pump
itself. Remove the hoses from the pump in order to remove the article of
clothing. Keep in mind that any water in the washer will pour out of
the hoses when removed.
The F2 error codes means LONG DRAIN TIME and the suds code the washer detected water in tub after normal alloted drain time...so basically the F2&SUDS means the same thing. A lot of times when it does not drain fast enough,its caused by a blocked filter on the pump being biult up with debris. This tip i wrote will show ya how to clean the pump filter. http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
