SlingPlayer for iPhone/iPod touch, SlingPlayer for iPad offer TV-out feature ... Video out only works with the Slingbox 500, 350, PRO-HD, or SOLO with the latest ... than the iPhone 4, iPad 2, or the latest iPod touch may not be able to use this trick. ... if both your iOS device and your Apple TV are on the same WiFi network
open settings . turn off wifi then turn it back on after 30 seconds.
go back to settings open the wifi settings and pic your router
be sure you have the right wep key. also down load wifi analyzer
and open . check to see if your router is on channel with too many other routers close by. this will cause you to have a spotty connection or none at all.
I had 5 other routers on the same channel from the same provider and actually the same router brand. move your channel to a blank spot. why galaxy products are so sensitive i do not know as laptops and pc's can lock on to a signal and galaxy products seem to continuously search for a new connection regardless of weather
it has one.
1 Reset your wifi Router;
2 FORGET your router details on your Fire and then rescan to find it again, reconnect.
It's possible that a neighbour has a new router, tv, telephone, bluetooth device and it's causing interfearance on your wifi settings. If the above simple fix does not sort things out you may want to go into the router and change you channel to a fixed service on channel 3-9 rather tahn AUTO.
Are you looking for the steps to make at twitch.tv/activate? Then you are in the right place. In recent times, it has been the most viewed gaming channel. So, let us move forward to see the requirements to get into this channel. https://twitch-activate.com
Good day, I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog. The converter box will be set to channel 3, and you should set your tv's to channel 3 as well. Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan. When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separateChanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started. The converter box takes place of the tv's tuner and in essence disables it.
