Question about Canon PIXMA MP470 All-in-One Printer
It says that there is jammed paper in my printer but I cannot see it, how do I take the printer apart to take it out?
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 1463 Answers
SOURCE: error message
hi silv
just seen this post , if still getting trouble with the printer you can try here - PIXMA MP500 -
type in the ? for results.
riz.
Posted on May 12, 2008
Anonymous
  • 42 Answers
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Posted on Nov 21, 2008
eric400
  • 66 Answers
SOURCE: D880 Imageclass - paper jam - accordioned in
the jam is in the fuser assembly. you will have to have a technician fix this. the fuser will probably need to be replaced.
Posted on Apr 13, 2009
I have a 4500 office jet and the paper is severly jammed. can the printer be taken apart to fix this problem
Yes; there is a great (official HP !) video tutorial on how to take it apart properly here:
Jul 17, 2014 | HP Office Jet 4500 G510n
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
Printer will give a message of paper jam appears to be unable to pick up paper from tray . Can I fix this with a new paper tray if so where do I get one ? Or is there a better solution
I have worked on many a printer and I have yet to find one that when it says there is a paper jam is lying. You may need to take the printer apart to find the jam. It can be the tiniest of paper and can be located in an area that is difficult to find without taking the printer apart.
It also may be that the rollers that pick up the paper are bad. These should be easily replaced. Check the manual or help support online with the printer manufacturer for replacement parts. Typically the paper tray does not have the rollers so replacing the tray may not help you.
Apr 27, 2011 | Brother HL-4040CN Laser Printer
I have a hopeless paper jam in my HP L7580 and am sure i will have to take it apart. Do you have any instructions, diagrams or exploded views?
dont take it apart,you might gonna break your printer just remove paper from the back remove duplexer hen check for any loosed paper,pull the paper out,check compartments aswell turn off printer unplug power cable the check jammed paper inside the compartment 1,2,3...to check compartments just lift the middle part of the printer.
Mar 30, 2011 | HP OfficeJet Pro L7580 InkJet Printer
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Paper Jam with no Jam
We have the same problem. Do not by shit next time
Nov 12, 2007 | HP Photosmart 2575 All-In-One InkJet...
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Canon PIXMA MP470 All-in-One Printer Logo
176 people viewed this question
Clive
Clive
old marine
old marine
Ekse
