Hdd failure imminent. screen message during boot.Need t reinstall OS Windows Vista CD/DVD drive busted. 2 Disc for system recovery. If I create an ISO of both needed disc's onto flash can I use them to reinstall the OS? or do I need the CD/DVD drive to do so? I have made an ISO of my windows 8 disc for another unit and it works on Reinstall from flash but with this Vista being 2 disc's I am not sure how to do so.
Http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive.
A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users
To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Testimonial: "First off you didn't fully read my post. For had you you would see I don't need to boot I need to reinstall. Booting makes no difference when you need to reinstall a complete system. Man people are so ignorant lately in response like asking microsoft anything They don't read things either."
FIRST OF ALL THESE ARE GUIDE LINES. DID YOU EVEN READ EVERYTHING. IF YOU DID YOU COULD OF SEEN HOW TO REPAIR , REINSTALL WINDOWS. FRANKLY IT IS YOU WHO IS IGNORANT TO FACTS. R E A D AND DON'T S K I M. HAVE A NIC E DAY. THE METHODS CAN BE DONE FROM A FLASH DRIVE, CD ROM DRIVE, OR EVEN, AND PLEASE PAY CLOSELY. A FOLDER FROM YOUR HARD DRIVE ITSELF. IF YOU DON'T UNDERSTAND RATHER THAN PUT PEOPLE DOWN THEN ASK THE QUESTION IN A DIFFERENT WAY OR FRANKLY GO SOMEWHERE ELSE FOR THE ANSWER. HAVE A NICE DAY.
http://www.ebay.co.uk/itm/Compaq-Presari...
A replacement DVD ROM less than $12. What are you talking about!
With a replacement DVD ROM you are free to reinstall from your backup system discs.You have a nice day ....
except for the fact that, if you read the question, his DVD disc had quit on him and not his drive. And just so that you know the link that you have is for united kingdom and not united states. So much for $12.
Anyway R E A D the Q U E S T I O N and don't assume. May You have an nice day...
which is why my very first answer is STILL correct. have a nice day Sir.
