How can i fix the missfire on a cylinder toyota corolla 2000 1.8ltr
First you need to retrieve codes from the Engine control module. You can buy a cheap code retriever at harbor freight and get the codes. After you get the codes, if it is P0301 it means cyl #1, P0302 = cyl #2, P0303=cyl 3 and P0304= cyl 4. For ex: if you got P0301 you should remove the ignition coil #1(near the front of the engine, where the pulley is) and change its position with the coil # 2. Also remove the spark plug #1 and change the position with the spark plug #4. Clear the codes and start and run the engine until the check engine light goes on. Check for codes and see if the code change for a different code. If it change the position observe which one is the change. If is P0304 you have a bad spark plug, If it is P0302 you have a bad coil. If it repeat P0301, you have either a low compression, bad injector/connector, bad intake gasket them you should continue your diagnostic. I hope this help you.
Junior.
