Question about Roku Televison & Video
We put roku stick for 33 inchsamsung tv.suddenly it is not working. We tried anothet roku stick. It is also not connecting. Tv says no signal. The roku stick is loosefor the tv. tv
    Master:
  • 414 Answers
You need to make sure your network is set to connect on tv, and is set to wifi and connect to it to internet.
Posted on May 04, 2016
SOURCE:
tgvern
  • 281 Answers
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Posted on Dec 10, 2011
  • 110 Answers
SOURCE: What do I need to do in order to connect the Roku streaming stick to the internet?
Why do you need a roku if you have a smart TV?
Anyways, if you plug the connector into the TV via your HDMI port, it should power on. switch your tv to that input, and then use the remote to scroll through the setup options and find your wifi and set it up. it is a farily simple process
Posted on Jul 28, 2014
eyeintheskky
  • 121 Answers
SOURCE: How do I set up the connection on another TV in my house that I recently installed a roku stick for streaming.
Just call Netflix they will hook you up.
Posted on Dec 03, 2014
jerry_kramer
  • 3904 Answers
SOURCE: How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Posted on Dec 26, 2014
  • 544 Answers
SOURCE: Unable to connect to roku please try again later.. is the message on the tv screen
I would disconnect the power going to the Roku Stick, wait at least a minute or so, reconnect the stick to the power supply. If this does not work contract customer support at this link: Contact Support
Posted on Feb 06, 2015
What's the Difference Between the Roku Express and Roku Streaming Stick?
Jun 23, 2018 | Roku Televison & Video
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
How to setup to tv
Do not put batteries in remote first ,instead plug in ROKU power plug and connect RCA or HDMI cables to Tv.Now put in batteries in remote,push home button on remote it should be sending a signal to your ROKU box,this may take a few minutes.If if it getting a signal a purple screen will show up on TV with the words ROKU in white,hit home button again and it should show connecting on your tv.If it connects it will give you a code ,write this down,it will also tell you to go to a ROKU site on the internet,enter that good on ROKU internet site and it will go through the ROKU account process.You need to give them information like a credit card.Roku will suggest channels many are free others you have to pay for others like HBO,Netflicks.Some have a free week or monthly trial offer,if you don't want them make sure you remove them from your ROKU account before the trial offer or they will start billing you on your credit card.You can search for channels on ROKU tv site.Depending on which ROKU you have you can get up to 2,000 channels most are free.
Feb 12, 2016 | Roku 1
ROKU STICK IS NOT STARTING AUTOMATICALLY.
Check plug in roku stick and in electrical outlet for a good connection pull out and push back in..Their is a small reset button on ROKU,push it ,it will then show a blinking white light,if not you may have a bad roku stick.
Hook up ROKU stick BEFORE you put batteries in remote,after you put in batteries you will have to push button near batteries.
The remote should start blinking a green light this means it is trying to pair up with roku stick.If it does a purple sceen will appear on tv.Push home button remote and tv should give you a code.This code has to be entered at ROKU site link on computer.
Jan 29, 2016 | Roku Streaming Stick
How do I get it to work?
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into ...Roku Search makes it easy to find what's on, where you can watch it for free, ... At a wifi-enabled hotel or dorm room, just use your connected device to sign in ...
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...
Roku Streaming Stick Review & Demo - YouTube
? 5:03
https://www.youtube.com/watch?v=mSqMMJSPkBU
Oct 29, 2012 - Uploaded by totalhtpc
Many described the Roku Streaming Stick as one of the most promising ... My Tv does not have MHL port how to use thisRoku stick? thank you.
Dec 19, 2015 | Roku Streaming Stick
How can I jail brake it
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...Missing: jailbreak
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into just about any TV with HDMI® and start streaming your favorite content. ... (for remote); USB power cable + wall adapter; Get started guide; Special content offers.Missing: jailbreak
Roku Streaming Stick channels - YouTube
Dec 15, 2015 | Roku Streaming Stick HDMI Version
Jan 09, 2015 | Roku Streaming Stick
Why doesn't my ROKU streaming stick work on this TV?
If you are cornered and baffled over which streaming device to purchase, you need to examine the new Roku streaming stick. We have created this article simply for you to let you know the features of the Roku streaming stick which best suits users streaming needs. We are on an online informative service too to help Roku users get the best info and assistance on almost all of their streaming players and other technical assistance.
The new Roku streaming stick is recognized as among the finest devices you could discover at this lowest price for the features it offers. The "Private listening" feature is usually accessible on the Roku streaming stick, allows users to automatically mute the particular TV's audio tracks and listen closely to the sound through the private hearing jacks provided along with device package. The user can also use this same feature through their mobile remote app.
The app seems to be well sync with these new new Roku streaming stick and found to be much efficient with this device. Although the developers say it is about the same streaming speed since the Roku 2. If you are seeking for that most effective "ac" Wi-Fi standard, which an individual can anticipate finding in the Roku 4 and Chromecast, then you are about to be disappointed. The remote features finds to more responsive and is incredibly very good and quick.
The Roku device takes about 28 seconds to get it powered, which often is quicker than its peer brand names like Chromecast and Amazon Fire TV stick. They perfectly suit into the HDMI plug-ins of all most every TVs. In the event if the user find an problem in fitting them to the TV then use the Power cable to perform the trick. Attempt to make use of the port saver, if the connection to the TV is not appropriate or too tight. The user should never overlook using the remote app, which allows streaming easier for Roku users.
Hope this article let you understand the features and functionalities of Roku Streaming Stick. In case of any assistance required on purchasing or activation of these Roku products users can contact our team experts for instant and reliable technical solutions. Users can contact us through the toll free number at +1-888-269-1011 or visit www.go-roku.com.
Aug 03, 2014 | Televison & Video
Televison & Video Logo
256 people viewed this question
Top Roku Televison & Video Experts
Thomas Stauber
Thomas Stauber
Brandon Black
Level 1 Expert
ray gallant
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
