Kenmore top load washer mod #11046472500
See if this link will help
Model Help Repair
SOURCE: Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
SOURCE: Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
SOURCE: kenmore model 110 will not start drain cycle-top load washer
If the machine agitates, you probably have a bad pump. This is pretty straightforward repair, and I'm sure I can help you if you think you can do this yourself. Follow this link to a previous explanation on cabinet removal and you will find the pump right in front of you when you get the cabinet off. The part is relatively inexpensive to obtain from a local appliance part store. Changing is very simple. Hope this helps you :)
http://www.fixya.com/support/t2827272-kenmore_washer_model_23922200_not_spin
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
