I prefer to set the heat manually, rather than use the program.
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
Without a model number, it's hard to help Ya out, but most manuals are here: http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
Geno
SOURCE: honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR. Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
