Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
First you need to make sure that the keyboard is programmed to accept the DP-10 as factory default and then that the DP-10 is working perfectly. There is a case where the DP-10 action switch is activated directly, in this case the sustain does not stop and you need to change the micro switch of the DP-10 pedal. It has already happened to me and I replace it by adapting another micro because Roland does not support you and wants you to buy another DP-10.
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Your Xtalk filter is set too low. Refer to the owners manual for how to adjust individual triggers' sensitivity to "cross-talk" (vibrations carried from other pads)
My bet is you unplugged the crash trigger, but not the cable from the actual module (the brain). If you have a cable connected to the brain but not to a trigger, than any little bump to the end of the cable that isn't connected can be picked up as though you hit the pad normally. (play with the end of the cable a little, you'll see what I mean. It's kind of neat.)
