first go to application manager, select the youtube app, options and select view access, select data access and choose always allow, select your default access point under connectivity and save, if problem still persist you may have to update your phone.
there must be application error in your phone.. restart your phone and access your date and clock . if still having same problem then reinstall the OS of your phone. this will fix your problem. re install your phone and use it
Communication error problem are coming from your telephone provider. Call them and tell them that you are having a communication error while accessing facebook. Only your telephone provider can fix you problem. Have a good day.
you download the java software first before you can run: on the
phone to find your JAVA applications. Then select the section to stop
the application software, press the left soft key operation, go to see
the applications access the. Application access - communication -
network access, if the software has a license certificate, then select
Always allow, no election for the first time asked.
application software access - communication - data interchange, if
the software has a license certificate, then select Always allow, no
application software access - data access - read user data, select
Always allow the software without authorization certificate for each
inquiry to the election.
application software access - data access - increased selection and
editing of data is always permitted, the software did not authorize the
certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always
prompt " allow network access " this problem, this method is suitable
for the Nokia S40 operating system models.
Try going into Tools -->Settings -->General --> Date and Time to make sure that your date and time entries all are properly set before going to the Clock app. Hope this helps
I think not, as long as you have a bandwidth more than 128 kbps, then it's ok. Have you tried using an AC powered USB Hub? What operating system do you have? Have you tried plugging it to a different USB port?
hi sir remove the memory card and try. phone application will run. if it run's then insert the memory card if the same problem continue's memory card may be corrupted.. try to format it and use.thank's sir..
