Question about Xitel INport Deluxe
Error message: "LP Recorder has terminated/Unspecified error/Setting mixer control (0047D3A9)
Trying to set upo to record and I get this message. What to do?
How do I flip from cd and dvd's in recordings and transfer to then from vinyl's
sorry I don't know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nov 12, 2014 | Xitel INport Deluxe
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
I have been dubbing DVDs in high speed in SP mode successfully, but am not able to do so in LP mode. My DVD recorder shows error everytime whenever I attempt to record a DVD in LP mode.
There's a setting to record in high speed mode and I suggest you always do that. If a recording in SP doesn't fit on a standard disc I think you will find it won't dub at high speed either
Sep 16, 2010 | Panasonic DMR-EH60 DVD Recorder/HDD...
"Cant' find audio output mixer line for Line (USB Audio)(0047C6C0
I got this error when first running version 5 on Windows 7. So I tried running it in Windows XP SP3 compatibility mode, which solved it for me.
May 31, 2010 | Xitel INport (HFLI1X1) Audio Input
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
EZD880 unit not burning disc, "unspecified recorder error" msg
Hi Paul.
Try going to the DVD drive manufactures website and look for your specific model, see if there is an firmware update. This may fix the problem that you are having. Hope this helps.
May 23, 2017 | EZ Dupe EZD880 DVD RW Burner
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Nov 03, 2008 | Panasonic DMR-ES10 DVD Recorder
Problem Recording Audio
Check whether your PC connection is 'composite video', otherwise u have to use a separate audio line in and a mixer support to achieve adding the audio.
The lack of audio may occur due to driver setting or due to setting error in your digital recorder (DV cam). Try setting the same in your dv cam thru the setup menu...
Also don't forget to check the integrity of the connected audio cables :)
Good Luck
Have a nice day
Jan 25, 2008 | Ulead Videostudio 8 for PC
Xitel INport Deluxe Logo
241 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
Peter Dragonetti
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
