SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: How to access voicemail remotely for kx-tga101s?
To access your messages remotely, after the greeting message starts enter in your remote code (default setting is "111").The unit will tell you the number of new messages then give you number commands to use additional features. When finished hang up.
Testimonial: "Quick response to original question then followed up quickly when first answer didn't work. Thanks!"
SOURCE: I've lost my manual for my KX-TGA101S Cordless
You just got the manual for the handset. What you want is the one for the base unit. http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
SOURCE: I have a panasonic KX-TGA101s
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
