Computers & Internet Logo
Ahmed Awad Posted on Jan 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 0xc000007b problem loading games like blur help please
matt
Level 3:
  • Dell Master 1,666 Answers
  • Posted on Jan 11, 2016
matt
Dell Master
Level 3:
Answers
1666
Questions
Helped
696283
Points
9998
Fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
3answers
How to Fix MS Office Error Code 0xc000007b?
If legit software, contact MS. Or just google it just as you presented it here. There are many answers for you to check out.
0xc000007b error xp
"The application was unable to start correctly 0xc000007b"
Read the answer given by Microsoft technical support at the URL below.
0xc000007b error
0xc000007b
did you download that game, if so uninstall and re-download again. still showing that error try downloading from another site
11helpful
Error 0xc000007b
download this fixer from http://dlc1.paretologic.com/regcurepro/RegCureProSetup.exe
Assassin creed 4 0xc000007b error
Download Reginout to fix 0xc000007b error simply with some couple of clicks.
If when run my game 'dark sector' it says that the application cannot open(0xc000007b). Why it says like that and tell me a solution to run my game and play it. please post a better solution...
The best solution is to do as the game tells you. It knows the exact spec of your computer, but, you haven't told us the make or model number of your computer, so we can't help!
2helpful
Program error 0xc000007b
You didn't post what you were doing when you got the error? Take a look here: http://www.tomshardware.com/forum/63536-63-error-0xc000007b
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
