Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Remote will turn fireplace on but when reaches set temp will not turn the fireplace off
The fireplace won't turn on when it gets below the set point on the remote. The flame icon is on and I think it's keeping the fireplace from coming on.
That's because you have reached your desired room temperature as set on the remote. Raise the set point to a higher value.
Dec 14, 2017 | Heating & Cooling
My Mendoza fireplace is reading about 14 degrees below temp in house. Is remote bad.
It'll depend on where the temp sensor is located on the fireplace, I'm assuming it's low to the ground so it'll read lower than mid wall stats or temp gauge if your standing
Sep 20, 2017 | Heating & Cooling
Why does my fireplace insert go on and off when I cchannel my tv remote up and down any solutions please and thank you
Samsung Anynet+ switching input modes when tv is turned on ...
www.cnet.com > Forums > Samsung
CNETMy recommendation would be to hook an Anynet+ device up directly to ... My TV (HDMI IN 1) is connected directly to my receiver with an HDMI cable ... Without that connection connected, it will by default go to the blank screen you're describing. .... I just want the anynet function to know that the dvd is turned off and to switch ...
tv remote turns on fireplace.. Help!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 25, 2014 - we just got a vizio smart tv and it sits on a electric fireplace but every ...on the tv remote it turns on/off or changes the heat temp my fireplace!!! ... the makers of electronics such as televisions and receivers do go out of ... A/C remote and it might change channels on the TV or raise the volume ... Thumbs down.
Your remote reprogramming woes solved - Rogers RedBoard
Dec 15, 2015 | Heating & Cooling
Gas ventless fireplace remote will not work have inserted new batteries in both fireplace and remote but fireplace not recognizing remote
Every time the batteries are changed in the receiver and transmitter the transmitter has to be "re-learned" to the receiver. To do this locate the "learn" button which will look like a tiny hole so you have to stick the end of a pin or a pen in the hole to press the button. Hold the button down until it beeps at you 5 times and release. press the button again and release and then press Any button on the transmitter.
Once the receiver is set into its "learn" function it does not matter what button is pressed on the transmitter because the next signal the receiver picks up will be the frequency it is attached-to.
In order to change the transmitter simply hold the learn button down until it beeps 5 times again which tells us it has wiped out its memory. Then press, release and press the transmitter.
Nov 20, 2014 | Real Fyre 24" Forest Oak Ventless Natural...
Majestic gas fireplace troubleshooting
Is your log set remote driven? Do you have the room temperature set in it? You may have inadvertently set the room temperature for a certain range. Or you may have a thermopile going bad. Do you have any other remote driven appliances affected at the same time? I.E.: Do you change tv channels and the logs go off?
Dec 05, 2013 | Home
Febo Electric Fireplace Insert Using remote It Will Not Auto Shutoff when room reaches temp. also If room is Cold & Temp is set higer it will not turn on. U have to manually shut it if or on. there is...
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Oct 24, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Jan 02, 2010 | Heating & Cooling
Heating & Cooling Logo
114 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
