How do you wire up 2 hampton bay fans using one switch?
I'm not sure how your set-up is, but I can definitely walk you through it. To simplify it on my end. Let's start with the neutral (white wire) wire first - and to be honest with you, this ISN'T always true out in the field, especially in homes (residential wiring). But, let's assume this has been verified. And before I start, make sure the power is OFF. Now, you want to take this neutral (white) wire to both fixture's only. The neutral (white) wire does NOT go to the switch. After you hook up the neutral wire to the one fan - then connect this to the second fan. They should be connected together (in series with each other). Okay, now that we have the neutral (white) wire connected, and out of the way...you want to connect the other wire on the fixture (most likely black) to the other fixture's wire (black) - and take this down to the switch. So now, you have both fixture's hooked up - with only the black (which will be called the switch leg) going down to the switch. Then, you'll need to find your constant HOT wire (which might also be black) - and take that directly to the switch. So now, the HOT wire brings the electricity down to the switch. When the switch is turned on - then the switch leg (black) wire will send the electricity up to the light/fan. Once the light/fan is in operation - that means the neutral (white) wire - has received the electricity (load), and taken it back to the electrical panel...completing the circuit. THIS, is how it all works. The HOT wire leaves the circuit breaker, and goes directly to the switch. Once the switch is turned on, then it travels up the SWITCH LEG to the fixture. Assuming the switch on the light/fan is ON - which is what you want when working it off of a switch - then, the NEUTRAL wire takes the electricity (load) back to the electrical panel...Completing the circuit! Also, the ground wire's should've been hooked up first - but if there's no grounding available (which happens a lot in homes (residential applications), then don't worry about it. It's a good practice to have all appliances, etc. grounded. You can get a grounding clamp, and ground it to the cold water pipe on your water heater - then run it into the ceiling, and to your light(s). This is for added protection! It will trip the circuit breaker if there's any short in the circuit. I hope I didn't get to complicated here, but feel free to contact me with any further question's. Good Luck, and be patient as you can. You'll see that you can do this...
