The Maestro and light wire and power are in one box. the next location controlled by a Maestro Companion works fine, but there's a 3rd Companion at end of circuit. I'm not sure where the final wires go. I use the recommended setting, black wire is a traveler so it goes to brass screw, Red wire to Blue screw, green is Ground. But what about White Neutral wire? Where does it go? I tried to just end it loose with a wire nut, but won't work. Suggestions?
