Unable to locate a manual specific to your machine, however, this may be helpful. Look at page 24 of the manual, picture #4 shows the bobbin shuttle. There are two flippers that hold the bobbin shuttle in place.
the bobbin is the bit that you put the thread on
it then drops /fits in the bobbin case
when you put the bobbin in the case you have to pull the thread around until you find a slot and pull the thread around under a flat spring
then you drop the lot into a bobbin case carrier
go google and type in-- user manual for( make and model) sewing machine and that will give you a site with a pdf version down load on how to basically set up the machine to sew
Other than that take it to a service center for any type of sewing machine and they will probably have any missing parts or be able to get the parts if required
Pop an empty bobbin on the thread spool. You need to disengage the motor from the presser foot so that the motor no longer makes the presser foot go up and down, but sends the power to wind a bobbin on the thread spool. Check with your machine's manual, but this is usually done be either pushing in, or popping out a button on the hand wheel. Begin a new thread on the bobbin following the directions either from your manual or as printed on the machine. On my Bernina, I have to push the thread spindle sideways to engage the bobbin winder. Use your foot pedal now and the bobbin will automatically fill up. It should stop when full, then you reverse your actions. eg: push the thread spool back, pop in the button on your hand wheel, insert the bobbin (check with your user manual as to clockwise-anticlockwise, and yes it DOES make a difference!) Re-thread your machine (always with the presser foot up) and make a test stich.
I hope this helps and happy sewing.
when a sewing machine sits up & is not used the oil & grease sometimes clog up the machine, & also if the bobbin spindle has jumped time then it will have to be fixed at a sewing machine shop I would suggest taking the machine to another sewing machine shop somewhere else & have it checked
