Panasonic Viera TH-50PZ80U Plasma TV Logo
P
Philip Howson Posted on Jan 10, 2016
Why is there back bar in middle of screen? - Panasonic Viera TH-50PZ80U Plasma TV
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Samsung 32inch d580 series 5. has two vertical color bars in middle of screen. have checked ribbon tape connections.
how about re seating the lvds cable in the t-con board doesn't work. if not, check for cold soldered component at the x board just re soldered it.
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
3helpful
3answers
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
9helpful
2answers
Orange world icon in middle of wallpaper screen is it possible to remove it?
on the main screen open the widget bar on the left then simply drag and drop orange world on the widget bar
2helpful
2answers
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Reb bar in middle of screen when using component input
there is a problem with your ps2.have it check by a tech.good luck.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
