I purchased a Audubon singing bird clock and it worked fine for the first month. Then the birds stopped singing. I changed batteries and it still doesn't work. Any ideas how to fix it?
Birds were singing every hour then just stopped. Batteries were not the problem. I pushed the red button too and that still didn't help. Clock works fine but the birds won't sing anymore.
No fix, other than replacing the time movement, which is a switch movement that can be purchased at several different clock part supply stores, catalogs, or websites.
SETTING THE TIME: ( Remove all batteries before setting) 1. Turn the hand set knob in the rear of the battery compartment clockwise or counter clockwise to read 10 minutes before 12:00 o'clock (11:50) 2. Insert three " AA" batteries into the battery compartment 3. Now turn the handset knob clockwise to adjust the desired time. Note: Each time the set test button"red" is pressed, this sets the birds melodies to the next hours bird. If pressed, you must follow the instructions above to reset properly or you will not hear the correct melody with the correct bird.
