Car Won't Start Because of Anti-Theft System That Uses ...
repairpal.com > Problems > Pontiac > Firebird
Car Won't Start and Security Light is On on Pontiac Firebird. Problems with the anti-theft systems using the raised-chip key can prevent the car from starting.
Security light was on and car won't start - CarGurus
www.cargurus.com > Questions > Pontiac > Firebird
CarGurusJul 24, 2007 - Check to see if your key chip isnt worn out(small silver thing on top part... My 1994 pontic firebird won't start and I no everything works great on ...
Pontiac Firebird Questions - security light - CarGurus
CarGurusFeb 5, 2009 - Hi I've recently bought a pontiac firebird the car doesn't have keys as previous owner ... Security light was on and car won't start 3 answers.
91 Pontiac Firebird won't start (Pontiac Firebird)
answers.edmunds.com > Edmunds Answers
Jun 18, 2008 - My '91 Pontiac Trans AM GTA will not start. When I turn the key, the engine does nothing, as if the battery were dead or the clutch pedal wasn't ...
SOURCE: 2000 f 350 won't start
check all of the vaccum lines and check the timing and see if they have any thing at the auto store for diesel to put in the tank you may have also got a bad tank of diesel fuel. i also had something like this once happen to me and the tank i got it was not diesel someone had put unleaded in that tank by mistake
SOURCE: is not starting , when u turn the key on- all the
any check engine light on? hate to say this but sounds like a ECM (brain) malfunction. but also sounds like a crank position sensor. if check engine light is on find the code and post it for more help.
SOURCE: takes a few sec to get it to turn over. cranks for
check the cables too the starter, sounds like bad ground connetions- bad battery connetions,some starters get burned in the relay so you wont get any power at first
SOURCE: It cranks fine, but doesn't even try to start.
check your securty light next time this happens if it is on you key or lock cyl is not reading the key
SOURCE: wont start
I understand you replaced the relay but not the pump, right ?
Has the fuel filter been replaced recently ? Are you sure there is gas in the tank ?
You should be able to jumper the pump relay and check fuel pressure.
