I have a 2008 Honda CRV with a viper 1400xp. It just recently began not working. The remote starter will try three times to start the car, but is never does. The engin does crank for about 1.5 second but it never starts. I upped the crank time to 4 seconds just to see if the car would start, it would not. When I use the key it takes about 1.8 seconds to start. I tried using the remote starter with the key in the ignition but it still won't start it only cranks. It is almost like the starters security system kill switch engaged, but I can start the car with my key so it can't be that. Any ideas?
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Did you install a OEM security bypass module? If no bypass module is installed your car will just crank and not run...
Can u help me
