Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson all in one printer, only just brought, not set up to wireless yet, just trying to get it to copy, can anyone help?
Epson wf 2630 all in one printer Epson all in one printer, only just brought, not set up to wireless yet, just trying to get it to copy, going around in circles on the setting up, carnt seem to print anything from copy, not much hair left, can anyone help?
6ya staff
SOURCE:
Anonymous
  • 150 Answers
SOURCE: epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
Posted on Jul 18, 2008
Anonymous
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
Anonymous
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Posted on Feb 27, 2009
Anonymous
  • 51 Answers
SOURCE: Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Posted on Jun 10, 2009
Anonymous
  • 15 Answers
SOURCE: Trying to connect new laptop wirelessly to Epson Workforce 600
You need a wireless router and then follow the directions that came with the printer.
Posted on Jul 13, 2009
WOT DOES ADF MEAN ON MY EPSON WF-2630
ADF is an outomatic document feeder on top of the printer. That's where you put paper that you want copies or scans of. See video below.
Apr 15, 2016 | Epson WorkForce WF 2630 Wireless Printer
New setup-- doesn't recognise the ink cartridges --- correctly fitted
Did you fix the black cartridge in the black and the corresponding colours correctly? Did you make sure that you removed all the plastic covers from the cartridges? Disconnect all the cables and Switch off the printer leave it for a few minutes and reconnect the cables and switch on the printer and it should work.
Nov 06, 2015 | Epson WorkForce WF 2630 Wireless Printer
How do i fix printer error 0xF3
Error Code 0xF3 means a hardware failure. If you are still under warranty, Epson will replace it.
Oct 08, 2015 | Epson WorkForce WF 2630 Wireless Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
