Lanzar SNV695N 6.95" Dd - Nav W /bluetooth Logo
L
Larry Choo Campbell Posted on Jan 09, 2016
I can't find adjustment setting for the clock on the navigation screen.
I set the time on the radio, but the day, month, and year won't stay set
Sara Lynott
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Oct 02, 2018
Sara Lynott
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
7589
Points
45
Have you looked in the car owners manual? You can most likely find this on Youtube.
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
How can I get the correct day of the week? I can get the date-month & day, but not the correct day such as Sat when the clock says Monday.
check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
1helpful
2answers
Setting the Sharp atomic clock SPC315
Sharp SPC315 Clock Setup Instructions
Set Time Hours and Minutes:
Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Adjust/Channel button to change the hour.
Press the Time/12/24 to go to minute
Press the Adjust/Channel button to change the minute.
Press the Time/12/24 to set.
Set Alarm1 and Alarm2:
Press the Alarm1/Alarm2 button to toggle either Alarm1 or Alarm2 to set.
Pres the Alarm1/Alarm2 and Alarm2/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Alarm1/Alarm2 to go to minute
Press the Alarm1/Alarm2 to set.
Set Calendar Year:
Press Calendar/C/F and Max/Min buttons at the same time for two seconds and it will start to blink the calendar year.
Press the Adjust/Channel button to change the year.
Press the Calendar/C/F to go to Month.
Press the Adjust/Channel button to change the Month.
Press the Calendar/C/F to go to Day.
Press the Adjust/Channel button to change the Day.
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
2helpful
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
2helpful
This clock is an automatic set clock and it is 15 minutes ahead in each timezone and is not able to be reset by us
Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
2helpful
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Can't adjust month/date etc....
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
19helpful
Set time
To adjust this clock's time: Press and hold the Alarm
Set button for 5-7 seconds, and the year will
begin to blink, then press the "UP" or "DOWN"
button to set the year. Press the Alarm Set
button again to set the month by pressing the
"UP" or "DOWN" button. Press the Alarm Set
button again to set the day, again to set the hour
(be sure the AM/PM is correct), again to set the
minute, and once more to secure all in the
memory
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top Lanzar Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a Lanzar Clothing Accessory Expert? Answer questions, earn points and help others
