Televison & Video Logo
oniyelu gbenga Posted on Jan 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Soniq PT42SH plasma TV power on. No back light and no pictures
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 08, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067043
Points
28436
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Iv got a soniq 42" plasma TV model no pt42sh there power the light go green then go red can I get it fix or is it easy to get fix
Main digital board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
My Soniq 42inch plasma TV model no.QSP426TV2 makes
Is the clicking through the speakers or from the back of the TV? Do you get a picture and sound? It might be something that is warming up and expanding as it would normally if this is the case
2answers
2answers
Key lock on soniq plasma tv witout remote control
Unfortunately the key lock cannot be deactivated without a remote, for it will defeat the purpose of key-locking. You can order a replacement remote, you need to have the exact information of your TV's model/version ( the barcode on the back of the TV starts in REVxxxx).
Soniq 42" plasma, model pt42sh
Yes the problem is the power supply.You can do replacement of power supply if the power supply you replace is the same to the original power supply of your television.If did not the same there's a conversion in the wiring, it may be difficult for not technician and have no knowledge in electronics..Thanks..
15helpful
2answers
Soniq 42'' QSP424T keeps freezing
I have been repairing Plasma Tvs for some 3 years now and have found most of the problems caused are by Capacitors.Once again Soniq are no different to the others.The fault is on the main Video Control Pcb.Replace Capacitor C529 which is a 470mfd25v.This cap is mounted next to an inductor coil at the top middle of the pcb.This Pcb is the one which has the tuner and all inputs on it.
Good Luck AND PASS THE WORD AROUND. LET US KEEP THE SERVICE INDUSTRY GOING.
VIEWCLEAR VISION PL BRISBANE AUSTRALIA.
5helpful
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
20helpful
Soniq plasma will not power up
1.8 volt regulator on image pcb
POP goes the Plasma
You've lost the standby voltage, probably due to varactor or passive component failure...accordianman
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
