Washing Machines Logo
francisco orozco Posted on Jan 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fh error code wirpool duet washer - Washing Machines
  • robertnel235 Jul 23, 2016
    F/H:
    Condition
    No water detected entering machine or Pressure switch trip not detected.
    If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
    Or
    If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
    Check/Repair:
    Press PAUSE/CANCEL twice to clear the display.
    If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
    If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
    Verify there is not a siphon problem
    Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
    Check all hoses for possible leaks
    Verify pressure switch operation
    Verify flow meter operation
    Verify CCU operation
    If this is intermittent, it would be very hard to determine the cause.
    It can be caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
    Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Claude Kayser
Level 3:
Top Expert:
  • Washing Mach... Master 9,098 Answers
  • Posted on Jan 09, 2016
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067176
Points
28436
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
5 Related Answers
Anonymous
  • 1902 Answers
  • Posted on Feb 13, 2009
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Anonymous
  • 530 Answers
  • Posted on Jun 23, 2009
SOURCE: Maytag Fronload Washer Error Code FH
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Anonymous
  • 68 Answers
  • Posted on Dec 16, 2009
SOURCE: WHAT DOES HF OR FH MEAN ON A DUET WASHER MODEL
this error indicates water is not being detected coming into the machine. many things can cause this issue but start here
be sure that water valves are turned on. besure the filters inside the machine water valve(where hose hook to machine) are not clogged. also make sure drain hose is not installed into a drain pipe tightly. it should just rest inside a pipe or on the edge of a utility sink. when installed tightly into a pipe it creates a suction and syphons the water out of you machine and then your machine will never reach a "full" water level
WWW.LARTODAY.COM
Anonymous
  • 232 Answers
  • Posted on Dec 24, 2009
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
go 2 repair clinic on line, same codes for whirlpool duet repair help then error code tab
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
3helpful
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
FH Error code Whirlpool Front load washer. I
the only thing you can do is to go to the manufactures website and download the user manual and check the trouble shooting guide for a possible cause for this problem eric
2answers
FH Errors
FH error code has to do with no water detected or pressure switch trip not detected. is there water in the unit or is it empty? Joe
FH Code in Digital Window.
The fh is a fill error caused by one supply being low on pressure, a bad fill valve, a bad flow meter or a bad pressure switch or hose .
Top Washing Machines Experts
john h
