Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
SOURCE: replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
SOURCE: took oven door off to
We have http://www.youtube.com/watch?v=kESnnYR4VhM&playnext=1&list=PL716C400A1FAFA528&index=8
here below a link with a video which is shows how to replace the door hinges
and it will help understand how to unlock the hinges. The video is very clear
that we believe any description in words is not needed.
SOURCE: Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
its a side opening door with a roller lock? I just need to put the lock back in but i dont know how to do this. I think i may need to take the front glass off to put a nut behind the hole for the bolt to stay on but i dont know how?
