I remember how at the University at the first laboratory work I was almost exposed to all harmful fumes. The teacher made me write an entire essay on safety at work. I turned to Paperial.com for writing a quality essay. But since then, there have been no such incidents. Therefore, carefully read the safety precautions and the most important advice: to improve how well fumes are taken up and away, put your reactions or equipment as far back in the fume hood as you possibly can.
The heater will burn the fumes off , how long it will take I don't know.,can you put it out side and let it run till the smell goes, never spray any thing on the heater elements you could have a fire.
Perhaps you are asking about a "catalytic converter"? Wikipedia's best answer is: A catalytic converter is a vehicle emissions control device which converts toxic byproducts of combustion in the exhaust of an internal combustion engine to less toxic substances by way of catalysed chemical reactions.
More of the article at: http://en.wikipedia.org/wiki/Catalytic_converter
You would have to contact the makers of the heater to give you a clear answer on that , most heaters smell when first put on from new and you would have to burn this off first ,
If you have recently painted or varnished something then just air out the house. The fumes can react w/ the heat of the dryer to create this smell. It smells different than the actual fumes, but still like some sort of solvent.
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
if you are driving in the open and you have your hood down it would be unlikely for fumes to come out and stay in the car. if your hood is up check your exhaust pipes
your vehicle has a cabin air filter that needs replaced. the smell is going to be from the cabin air filter needing replaced as well as the transmission line leak. however your concern will be fixed with the cabin air filter.
