The buttons near the top of the console work but the Tension increase/Decrease, or the preprogramed buttons dont work.
SOURCE: I have a nordic Track
hi,
check the other push buttons on the control console. if found faulty replace it. it is the only thing u can do in the control console. if problem remains u should replace the control console with a new one. for that u have to consult the manufacturer.
do one more thing before consulting manufacturers, remove the control console put out its circuit board. using a hair drayer heat the whole board. do not over heat.. then re fix it and test it.
ok
SOURCE: Epic 425 Mx Treadmill EPTL88105 buttons dont work
1) Try to open the top consol.
2) Spray with contact cleaner( from radio schack or computer store)
3) Tight the flexible cable from keypanel vs display board
4) Tight the connector from display board to Lower board( Main Controller Board)
5) Test the main controller board.
6) Test the transformer.
Finally See the Block diagram that I did, you will see how the Main Controller Board has the 90% in any control. In that way you will have a good Strenght resultante, for to determine who is faulty. sincerely. Good luck.
E.CUADRA
MANAGUA, NICARAGUA. C.A
SOURCE: The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
SOURCE: I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
sincerely. God bless you
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
