Vehicle Parts & Accessories Logo
W
Williams Vigil Posted on Jan 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the denso spark plug gap for fxu1ghr11 plug?
Geoffrey White
Level 3:
  • Master 3,965 Answers
  • Posted on Jan 10, 2016
Geoffrey White
Master
Level 3:
Answers
3965
Questions
Helped
913746
Points
10651
For most cars, 1.1 mm
Testimonial: "Thanks! I have come across different gap sizes for the 2011 Sonata Limited; 0.8mm and now 1.1mm. My old Denso plugs (80,000 miles) were 1.1mm."
tip
1995-1997 HONDA FOURTRAX 300 SPARK PLUG APPLICATIONS AND GAP
1995-1997 HONDA FOURTRAX 300 TRX300 & TRX300FW
SPARK PLUG APPLICATIONS & GAP
Only have specs on the 95-97 in front of me. Will update with entire 88-00 info as soon as possible.
GAP: 0.8-0.9 MM - 0.031-0.035 IN
STANDARD RIDING:
DPR8EA-9 (NGK) X24EPR-U9 (DENSO)
COLD CLIMATE (BELOW 5° F/41° C):
DPR7EA-9 (NGK) X22EPR-U9 (DENSO)
EXTENDED HIGH-SPEED RIDING:
DPR9EA-9 (NGK) X27EPR-U9 (DENSO)
on May 16, 2016 • Cars & Trucks
Spark plug gap for dpr8ea
You can easily look this up on line at the NGK sparkplug site. Global Denso also has the info for cars and motorcycles. (The OEM sparkplug for your bike is either NGK or Denso... upgrade with Iridium Plugs for a bit more HP and longer life.) It's 0.035" The iridium Denso Plug is 5375 (IX22B)
Spark plug gap for 1969 dodge corornet 318
normally around .025-.030". Most new plugs come pre-set to the correct gap for most engines.
2helpful
What is the firing order for spark plugs on a 2006 Pontiac Vibe?
1.8L (LNK)Firing Order
1-3-4-2
Spark Plug Torque
18 N·m
13 lb ft
Spark Plug Gap
1.0-1.3 mm
0.040-0.051 in
Spark Plug Type
SK20R11 DENSO
1.8L (LV6)
Firing Order
1-3-4-2
Spark Plug Torque
25 N·m
18 lb ft
Spark Plug Gap
1.0-1.2 mm
0.040-0.048 in
Spark Plug Type
SR16R11 DENSO
Thank you and enjoy,
Lee
1helpful
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
