Mitsi has this information posted in regards to the 2 errors you have indicated. "2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect
(short protect monitors low voltage supplies)" Also these 3 tech notes were found. "1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010
AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB.
2.
SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND
F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE
CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES
SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT)
LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB." I hope this points you in the right direction.
When it shuts off. Try doing what's called a self-diagnostic test. As
soon as the television shuts try these steps.
Pressing on the
front panel's 'INPUT' and 'MENU' buttons at the same time, and holding
for 5 seconds, activates the Self Diagnostic Code Mode. The LED
flashes denoting a two digit Error Code, or indicating no problem has
occured since the last Initalization.
Note: The front
panel buttons must be used, NOT those on the Remote Control.
-The
number of flashes indicates the value of the MSD (tens digit) of the
Error Code. -The flashing then pauses for approximately 1/2 second. -The
LED then flashes indicating the value of the LSD (ones digit) of the
Error Code. -The Error Code is repeated a total of 5 times. -Example:
If the Error Code is ?24?, the LED will flash two times, pause, and
then flash four times.
The Error Code designations indicating a
malfunction, or no malfunction, are listed below: Self Diagnostic
Code Description 1 - 2 = no error detected 2 - 1 = X-ray protect
(high voltage or beam current) 2 - 2 = Short protect (short protect
monitors low voltage supplies) 2 - 3 = Deflection protect (this
could be loss of vertical or horizontal deflection) 2 - 4 = Vertical
protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Pressing on the
Note: The front
-The
Error Code.
-The
Error Code.
-Example:
then flash four
times.
Self Diagnostic
Code Description
2 - 4 = Vertical
this solution.
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC).
2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
Good Luck, big IRISH.
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Does the led light up when power is pressed? If so press menu and input buttons both in together to see if the led will blink a two digit error code then let me know the results. Please respond to this same post.
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code. ? The flashing then pauses for approximately 1/2 second. ? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. ? The Error Code is repeated a total of 5 times. Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below: Self Diagnosic Code Description 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source).
