NorStar M7310 Corded Phone Logo
B
Bill OBrien Posted on Jan 06, 2016
Some #'s I dial show "restricted call" and wont let me dial. How do I take this feature off?
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
How can I show restricted incoming numbers on my iPhone 3gs
you can try dialing back *69. I know when you press *67 BEFORE dialing it will show your number as being restricted.
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
I have a starplus sp7050-02 I am having trouble with forwarding calls. my phone company started a new program last week. I used to dial 72# and the phone would automatically transfer to the answering...
That's an easy one....sort of. If you have a DHS manual, you'll have to go into your restriction tables and allow *72 on whatever phone you are using, or better yet, put it into speed dialing where it is not subject to dialing restrictions. The reason for restricting * in the first place is because you can use other telco features like *82 and dial the world. It keeps your users from finding ways around toll restrictions. When * is required, you have to specifically allow *72 and *73.
Carl
3helpful
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
The display should say speed dial#:--
enter in the speed dial number you wish to program(40-70) .
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
1helpful
Deleting security code from Norstar Meridian M7208
Go to programming of Norstar bY Feature**266344 passwordwill be 266344.
Press show put the extension number then show the keep pressing next until display shows restrictions.Press show the next until dispaly shows ext rest. then show then show again and check what is the restriction filter number.
Press heading till u get restrictions.press show then show again. put the restriction filter code and delete or remove all restrictions from the filter and press release and come of the programming.
Restriction has been removed now.
After that u can easily make o/g calls without using any code.
Got new sgh-g600 wont let me do anything
You have enable the feature called "Fixed Dial List". You need your PIN2 to enable or disable this feature. Using this feature will restrict your calls or text messages only to numbers in the list.
Navigate to your phone security menu, and disable fixed dial list.
Regards,
dC
3helpful
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
4helpful
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
