E27 is the WASTE INK ABSORBER FULL error message. Try send it to service centre to do the WASTE INK ABSORBER replacementjob & waste ink counter reset job.
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed , or the ink cartridges are notinstalled properly E8 Waste ink absorber full, or platen waste ink absorber full E9 The connected digital camera /video camera does not support Camera DirectPrinting E14 The Ink cartridges whosedestination are wrong E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature riseerror E27 Waste ink absorberfull or platen waste ink absorber full E28 Ink cartridge temperaturerise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
hi, CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF) E3-3 = Paper jam E4 = No ink E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly E8 = Waste ink absorber full, or platen waste ink absorber full E9 = The connected digital camera / video camera does not support Camera Direct Printing E14 = The Ink cartridges whose destination are wrong E15 = Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 = Failed to scan head alignment sheet E22 = Carriage error E23 = Paper feed error E24 = Purge unit error E25 = ASF(cam) sensor error E26 = Internal temperature rise error E27 = Waste ink absorber full or platen waste ink absorber full E28 = Ink cartridge temperature rise error - E29 = EEPROM error E33 = Paper feed position error E35 15 = USB Host VBUD overcurrent error - USB E37 17 = Abnormal motor driver error E40 20 = Other hardware error E42 22 = Scanner error If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1 on the display on your camera.
However, because printing is disabled once the ink absorber becomes completely full and until the ink absorber is replaced, you are recommended to contact a Canon service representative as early as possible. *1 To resume printing, you can press [OK] (MP180) / [Black] or [Color] (MP160) on the machine instead of selecting [Continue].
