G
Gary Roach Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After moving doors willnot open
Also it will play
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 05, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061575
Points
28436
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Our DVD door willnot open
What kind of DVD play is it?
Do you have a picture or model number?
Sometimes the DVD gets stuck because it came out of the tray and a light tap will seat it back into place.
Door willnot unlock after wash is complete
switch is stuck. need to take the top off. and move the door lock to the side and open the door at same time make sure it is up plugged and has no power wile ding this. sometimes it can be easier and just turn the power off at the wall and wait 10min and it will be able to open. but if the switch has failed as they can do you need to do it the way at top of this. when open don't use until the door switch is fix as it will keep doing this on every wash.
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
REPLACE LATCH ON DRIVER SIDE FOR 1989 HONDA ACCORD
sounds like latch is not allined properly ,try moving striker pin a little in or out up or down ,slowly closes door to see if you feel any indecators as to what is the problem., good luck.
2helpful
2answers
1997 Mercury Mountaineer rear doors will not open from inside and child locks are not on almost seams as if the cables are streched
The inside door handles are plastic so the chances are you need a new one. To get to it you have to take the door panel off and than you will see
Garage door willnot open installed new socket gear
DID YOU SET THE CHAIN PROPERLY??
THIS IS IN THE INSTRUCTIONS AND IS VERY IMPORTANT.
IF THE CHAIN IS IN THE WRONG POSITION YOU COULD BE AGAINST THE UP STOP WITH THE DOOR CLOSED.
HOPE THIS HELPS
Driver door closes but willnot open
iside door panel linkage from handle to lock mechanism is where i would start
hope2help shack
Work light does not come on
may have incompatible console. did you get exact replacement.
Viewsonic pj551 projector lamp will not light
Without more info, I'll tell you some things to check...Make sure the power cord is still plugged in firmly. With the unit unplugged, check the lamp for damage, looseness, etc. Was the unit hot when you moved it? If it was, the lamp was more prone to damage due to the heat. Always be VERY gentle if you have to move a hot projector for any reason. Did the unit sustain any hard impact while moving? Impacts crack boards, loosen connectors, and damage lamps. Make sure the lamp door is closed completely--there is a switch on the door to prevent the projector from coming on if the door is open. Make sure you didn't press any buttons on the unit too hard while holding it during moving.
 Grubhead
Grubhead
SmartAviator
SmartAviator
