Key in switch turn and no click no start i drove down to office two blocks away no problems before came back put key in no click no start everything else fine. Disconnected neg cable for 20 min with key in switch key out connected back still no start. No dim lights no codes with scanner no bad fuses
SOURCE: ignition switch does not turn on my 2001 c320
It is possible the immobilizer ring is defective(thid ring reads the rolling and number codes form the key. Does your central locking work and does the l.e.d. illuminate when the central locking buttons are pushed. The batteries may be weak and if they are they would have to be replaced and the resynchronized. The resynch procedure is probably in your owners manual. The e.i.s. (switch) is a control module and a complicated replacement procedure- it also takes a good 10 days to get parts because they have to reload it with a special key that made for your vehicle only. Try cleaning the lens on the key. It would also be a good idea to have the e.i.s. codes pulled at a dealer or equivalent. if problem persists. If the car will not start. try disconnecting the battery and wait approx. 15 min. sometimes that will give you a couple of starts unless it is just a software issue. I believe after so many starts these switches have to be replaced because the codes are now illogical; basically they do not reset and go back to zero.
!st by changing your remote batteries you need to resynchronize your key. I believe you place it in the ignition turn and then remove and press your unlock button. The procedure will be in you manual. It almost sounds to me that the linkage is out on your trans and the car is not all the way in park. Look under neath and see if your shift rod is dangling from your trans. Next if it is not try starting the car in neutral. A common failure for that era is the shift box which allows the vehicle to start. Another problem could be is that your parked on a hill and steering son't come unlocked if this is the case crank on your wheel hard to allow key to turn. If all else fails call M.B. roadside it should be free
2001mercedes-benz320 will not start after losing power and died.
SOURCE: 1991 190e 2.3 mercedes key wont turn at all.
hello,good day,seems your steering lock mechanism is defective,or you can try to rotate your key, with patient ,maybe it turn,but you need to replaced the mechanism,ty
SOURCE: Start Error Message when turn the key. No clicking, Dash normal.
seems like your key is not being recognized, possible your tumbler..the ring around your ignition switch is bad
