Televison & Video Logo
A
Anonymous Posted on Jan 05, 2016
Remote not pairing - Hisense TL-3220 Television
Electro Med Services
Level 3:
  • Hisense Master 6,694 Answers
  • Posted on Jan 05, 2016
Hisense Master
Level 3:
Answers
6694
Questions
Helped
1871010
Points
21433
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://electro-medical.blogspot.com/
My Samsung solar remote blinks but will not sync at all the Bluetooth icon appears on the TV tho
The issue with your Samsung Solar Remote not syncing with the TV even though the Bluetooth icon is appearing on the TV could be caused by a few different things. Here are some troubleshooting steps you can try to resolve the issue:
  1. Check the battery: Make sure that the battery of the remote is charged and inserted correctly.
  2. Move the remote closer to the TV: The remote should be within 30 feet of the TV to ensure a strong Bluetooth connection.
  3. Turn the TV off and on again: This can help to reset the Bluetooth connection between the remote and the TV.
  4. Remove the pairing information: If you have paired the remote with another device before, it may have saved the pairing information and is interfering with the new pairing. Try removing the pairing information from the remote and the TV and then pair them again.
  5. Reset the remote: You can reset the remote by removing the battery, then pressing and holding the power button for 10 seconds, and then releasing it. Reinsert the battery and try to sync the remote again.
If these steps don't resolve the issue, try contacting Samsung support for further assistance.
How do you get your dish remote back In sat mode after you power scan
To get your dish remote back into sat mode after a power scan, you will need to re-pair the remote with the receiver. Here are the steps to follow:
  1. Turn on the receiver and make sure it is in sat mode.
  2. Press and hold the SAT button on the remote for at least three seconds, until the mode lights on the remote turn on.
  3. Press the pound (#) button on the remote, then press the SAT button again.
  4. Use the remote to select the receiver you want to pair with, then press the pound (#) button again.
  5. The remote should now be paired with the receiver and in sat mode. You should be able to use it to control your dish equipment as usual.
If you have any trouble re-pairing the remote with the receiver, you can try pressing the reset button on the receiver and repeating the steps above. If you are still unable to pair the remote, you may need to contact dish customer support for assistance.
How do I link LG AKB73615337 Remote Control to my xfinity flex box?
The LG AKB73615337 remote control is designed specifically for LG TVs and may not be compatible with the Xfinity Flex box. However, you can try the following steps to see if it works:
  1. Ensure compatibility: Confirm that the LG remote control is compatible with the Xfinity Flex box by checking the list of supported devices in the remote control's user manual or by contacting LG customer support.
  2. Power on the Flex box: Make sure your Xfinity Flex box is powered on and connected to your TV.
  3. Activate pairing mode: Put the LG remote control into pairing mode by simultaneously pressing and holding the "Back" and "Home" buttons for a few seconds until the LED light on the remote starts blinking.
  4. Follow the Xfinity Flex box pairing instructions: Refer to the Xfinity Flex box's user manual or contact Xfinity customer support to find the specific instructions for pairing a remote control. This process may involve entering a pairing code or following a series of steps on the TV screen.
  5. Test the remote control: Once the pairing process is complete, test the LG remote control to see if it works with the Xfinity Flex box. Try navigating the menu, changing channels, adjusting volume, and performing other functions to ensure proper functionality.
If the LG remote control does not work with the Xfinity Flex box or if the pairing process is unsuccessful, it is recommended to use the original remote control that came with the Flex box or consider purchasing a universal remote control that is compatible with the Xfinity Flex box. Universal remote controls are designed to work with multiple devices and usually come with instructions for programming them to work with specific devices.
Remember to consult the user manuals of both the LG remote control and the Xfinity Flex box for specific instructions and contact customer support if you encounter any difficulties during the pairing process.
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
2answers
Samsung BN59-01223A Remote Control
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
How do I pair my roku remote
On the main screen go to SETTINGS and then scroll down to REMOTE PAIRING AND FOLLOW THE INSTRUCTIONS . It explains on the screen how to pair the remote. The remote is normally setup for the Roku unit out of the box.
It is telling me to pair my remote, what do I do?
If you already have a working remote, just cancel pairing. If your trying to pair an additional remote for game-playing, or "Remote-wars" just follow the on-screen instructions for pairing. Make sure you have fresh batteries in your new remote, and keep it within aproximately six feet while pairing.
What is pair your remote stick roku
Pairing usually refers to the Remote control. If your roku remote control is already working, you can ignore this.
Remote will not work
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  4. Turn on TV
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
