Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
Try forcing it to shut off.
Press and hold the Play button for 5 seconds (count slow) and while holding it flip the on/off switch to off. To turn it back on flip it to the On positing on press the Play button for 5 seconds again. This should hopefully fix the issue.
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash
would automatically power itself on when camera activity is detected but
when the flash is detached, it doesn't wake back up. To change this you have to turn off the auto shut off in the flash menu: 1. Power the flash on 2. Hold down the back light /C.Fn button until "Fn 00
0" appears on the screen 3. Rotate the selector wheel until you see
"Fn 01 0" 4. Press your selector button down so that the 0 begins
flashing 5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1 7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
