Cars & Trucks Logo
Petrus Erasmus Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a ford cvh 1600 what backfire through carborator only when it is hot and then lose its power
Claude Kayser
Level 3:
Top Expert:
  • Ford Master 9,098 Answers
  • Posted on Jan 05, 2016
Claude Kayser
Ford Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067055
Points
28436
Ford Escort carb backfire Questions & Answers - Fixya
www.fixya.com > Forum > Tags > carb backfire > Cars & Trucks > Ford
Ford Escort cars & trucks carb backfire questions and answers. ... Backfire throughcarborator and engine stopped upon returning from store. ... Turbo conversion from 1995 on a CVH engine - engine cuts out ... I have a xr3 ford escort 1600 with a weber carb,itbackfires and spits fuel up Clean the Carburator completely.
I have a xr3 ford escort 1600 with a weber carb,it backfires ...
www.fixya.com/cars/t10838117-xr3_ford_escort_1600_weber_carb
Nov 17, 2011 - I have a xr3 ford escort 1600 with a weber carb,it backfires and spits fuel up ... Turbo conversion from 1995 on a CVH engine - engine cuts out.
All comments on Ford Escort CVH Straight-through exhaust ...
https://www.youtube.com/all_comments?v=1yA5blCpTLM
I need to know on a ford cvh 1600 batam motor verchal timing marks an wht culd the problem be if i start it it drags i replaced the starter to it he wire gets hot their is a negative cable direct to...
Ford CVH is an old design but has proved itself long lasting and reliable. There is lots of information available about every aspect and the timing is among the simplest.
The weakest link has always been the water pump bearing that can fail very quickly without losing coolant. In the early days this was responsible for many bent valves.
To date I haven't experienced any problems with a dragging engine during starting that wasn't caused by the starter and/or battery. That the starter cable becomes hot indicates indicates it is consuming far more current than it should and mostly that would be the fault of the starter.
Does the engine spin over normally without the spark plugs?
1helpful
How do I set the timing on a Ford 1600 cvh bantam motor?
Hi
check timing marks on flywheel and crankshaft/pulley.
Remove no.1 plug to check it is just before tdc
1990 ford bantam 1.6 cvh W carb adjustments fuel consumption very high and smoking a lot and when I accelerate quickly in gear or still standing it sounds like a miss and it dies
the cvh has a weber carb. these usually need a service every now and then. the smoke suggests there is a over fuelling problem and the dying of the motor sue to some flooding, i fixed a cvh this past weekend with the same problems. make sure that all the air hoses are also connected to the various ports
How many degrees BTDC do I set my Ford 1.6 CVH motor
Most computer controlled engines have a base setting . the computer has to be uncoupled to set this , your manual will show this ,as most models differ.
1990 ford bronco idles fine when you accelerate the gas loses power and backfires through the intake
Fuel delivery problem, not enough fuel on acceleration could cause backfires. Many things cause backfires, mechanical and electronic. I need more info to give a better diagnosis. Did the problem happen all of a sudden or has the vehicle been running crappy for awhile.
Check the auto choke to be sure its not getting stuck.
My 1974 ford pickup/F250 3/4 ton loses power and backfires
It sounds like the timing is off but moore likely it's caused by the point gap being to close due to wear on the rubbing block.
The gap of the points effects the timing.
You probably need to clean and adjust the points.
If that doesn't work try replacing the points and if the old one are pitted, replace the condenser also.
If that doen't work check the coil.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
