Question edited into written English, 'no' and 'know' are two different words. And did you mean King Craft? There is none called 'Kraft'. Also model numbers are need in such questions, 6000 watt is just the output. some help in the link, but no idea if it is relevant to what you have.
turn on the ignition switch
check and bring the oil to the correct level
check for spark
check choke operation
check low oil level switch is operational
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Hello and Welcome to FixYa!
Please explain your query a bit more... What I understand is that you need to know what that 3250 W means. Actually this the power (approximately maximum) that can be generated using that equipment... Every electrical equipment consumes certain power e,g. Ceiling fan ~100W, Iron ~1000 e.t.c.
You wouldn't need any special electricity power as such.....
