First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set. The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control). To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
