If you want to solve your problem, click on the link I attach.
JOHN DEERE 4210 4310 4410 COMPACT UTILITY TRACTOR SERVICE REPAIR MANUAL
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
SOURCE: John Deere 4410 PTO error code. One long flash,
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
SOURCE: John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
