I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - 4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - 4 authors
